Api event io set project version description
API Endpoint: api/event/io/set_project_version_description/
Description: Set the description of a specified version of a Project.
0 REQUIRED (Integer number) Session ID
1 REQUIRED (Integer number) Version of the Project
2 REQUIRED (String) New version description
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/set_project_version_description/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ 1, 1, "New version description" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ 1, 1, "New version description" ]'
fetch("https://engine.tygron.com/api/event/io/set_project_version_description/", options)
