Api event io save session
API Endpoint: api/event/io/save_session/
Description: Save the current state of a SINGLE or MULTI Session. This does not change Project data and allows reloading the Session state later.
0 REQUIRED (Integer number) Session ID
1 REQUIRED (String) Randomly generated save token
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/save_session/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ 1, "Randomly generated save token" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ 1, "Randomly generated save token" ]'
fetch("https://engine.tygron.com/api/event/io/save_session/", options)
