Api event io save project
API Endpoint: api/event/io/save_project/
Description: Save the current state of an EDITOR Session as the current version of the running Project, updating its initial state for future Sessions.
| 0 | REQUIRED | (Integer number) | Session ID |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/event/io/save_project/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '1'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '1'
fetch("https://engine.tygron.com/api/event/io/save_project/", options)
