Api event io kill
API Endpoint: api/event/io/kill/
Description: Kill without saving a running Session.
0 REQUIRED (Integer number) Session ID
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/kill/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '1'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '1'
fetch("https://engine.tygron.com/api/event/io/kill/", options)
