Api event io join
API Endpoint: api/event/io/join/
Description: Join a currently running Session
0 REQUIRED (Integer number) Session ID
1 REQUIRED (Enumeration) Application type EDITOR, LAUNCHER, PARTICIPANT, SERVER, SHARE or TOOLS
2 OPTIONAL (String) Your computer name, for easy identification (optional)
3 OPTIONAL (String) Your client token, for rejoining (optional)
200 JoinReply (JoinReply)
curl 'https://engine.tygron.com/api/event/io/join/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ 1, "LAUNCHER" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ 1, "LAUNCHER" ]'
fetch("https://engine.tygron.com/api/event/io/join/", options)
