Api event io get continuable sessions
API Endpoint: api/event/io/get_continuable_sessions/
Description: Get all Sessions that you can continue, given your token pairs.
0 REQUIRED (TokenPair or multiple values in array [a, b, c]) TokenPair array
200 SessionInfo[] (SessionInfo array)
curl 'https://engine.tygron.com/api/event/io/get_continuable_sessions/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '
 "apiToken" : null,
 "clientToken" : null
Curl example multi item POST
 "apiToken" : null,
 "apiToken" : null,
 "apiToken" : null,
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '{ "apiToken" : null, "clientToken" : null}'
fetch("https://engine.tygron.com/api/event/io/get_continuable_sessions/", options)
