Api event io close
API Endpoint: api/event/io/close/
Description: Disconnect the Application from a running Session, optionally closing it if this was the last connected application.
| 0 | REQUIRED | (Integer number) | Session ID | |
| 1 | REQUIRED | (String) | Client Session token | |
| 2 | REQUIRED | (true, false) | Keep Session running, even if this was the last client | true or false |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/event/io/close/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ 1, "Client Session token", true ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '[ 1, "Client Session token", true ]'
fetch("https://engine.tygron.com/api/event/io/close/", options)
