Api event io add project version
API Endpoint: api/event/io/add_project_version/
Description: Create a new version for this Project.
| 0 | REQUIRED | (Integer number) | Session ID | |
| 1 | REQUIRED | (String) | Version Name |
| 204 | No Content |
curl 'https://engine.tygron.com/api/event/io/add_project_version/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ 1, "Version Name" ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '[ 1, "Version Name" ]'
fetch("https://engine.tygron.com/api/event/io/add_project_version/", options)
