Api event share set viewer input
API Endpoint: api/event/share/set_viewer_input/
Description: Set viewer content array for given path.
| 0 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Path (note: viewers end with a slash e.g. "mydir/viewer/") | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"] or matrix [["a", "b"], ["c", "d"], ["e", "f"]]) | Matrix of viewer input shareables (e.g. [["mydir/features.geojson", "mydir/Overlay-0.tiff"]], note: adding a tiff ending with "-0.tiff" will automatically add additional Timeframes like "-1.tiff") |
| 200 | Boolean (Content was updated) |
curl 'https://devshare.tygron.com/api/event/share/set_viewer_input/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Path 1", [ "A1", "B1" ] ]'Curl example multi item POST
curl 'https://devshare.tygron.com/api/event/share/set_viewer_input/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ [ "Path 1", "Path 2", "Path 3" ], [ [ "A1", "B1" ], [ "A2", "B2" ], [ "A3", "B3" ] ] ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '[ "Path 1", [ "A1", "B1" ] ]'
fetch("https://devshare.tygron.com/api/event/share/set_viewer_input/", options)
