Api event share move
API Endpoint: api/event/share/move/
Description: Move the Shareable to a new path.
| 0 | REQUIRED | (String) | Old Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/") | |
| 1 | REQUIRED | (String) | New Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/") |
| 200 | String (String) |
curl 'https://devshare.tygron.com/api/event/share/move/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Old Path", "New Path" ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '[ "Old Path", "New Path" ]'
fetch("https://devshare.tygron.com/api/event/share/move/", options)
