Api event share get viewer input
API Endpoint: api/event/share/get_viewer_input/
Description: Get viewer content array for given path.
| 0 | REQUIRED | (String) | Path (note: viewers end with a slash e.g. "mydir/viewer/") |
| 200 | String[] (Array of viewer input shareables.) |
curl 'https://devshare.tygron.com/api/event/share/get_viewer_input/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '"Path"'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '"Path"'
fetch("https://devshare.tygron.com/api/event/share/get_viewer_input/", options)
