Api event share get shareables
Revision as of 15:18, 20 November 2026 by Server@tygron.com (talk | contribs)
API Endpoint: api/event/share/get_shareables/
Description: Get all shareables in the given path. Tokenized shareables are included only for accounts with EDITOR level or higher.
0 REQUIRED (String) Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/")
1 OPTIONAL (Type or multiple values in array [a, b, c]) Types (optional)
200 Shareable[] (Shareable array)
curl 'https://devshare.tygron.com/api/event/share/get_shareables/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '"Path"'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '"Path"'
fetch("https://devshare.tygron.com/api/event/share/get_shareables/", options)
