Api event io start
API Endpoint: api/event/io/start/
Description: Start a new Session
| 0 | REQUIRED | (Enumeration) | SessionType: SINGLE, MULTI, EDITOR | EDITOR, MULTI or SINGLE |
| 1 | REQUIRED | (String) | Project Name | |
| 2 | OPTIONAL | (Enumeration) | Language: NL, EN (optional) | |
| 3 | OPTIONAL | (Integer number) | Preferred Session ID (optional) | |
| 4 | OPTIONAL | (String) | Group token (optional) |
| 200 | Integer (Session ID) |
curl 'https://engine.tygron.com/api/event/io/start/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "EDITOR", "Project Name" ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '[ "EDITOR", "Project Name" ]'
fetch("https://engine.tygron.com/api/event/io/start/", options)
