Api event io save session
API Endpoint: api/event/io/save_session/
Description: Save the current state of a SINGLE or MULTI Session. This does not change Project data and allows reloading the Session state later.
| 0 | REQUIRED | (Integer number) | Session ID | |
| 1 | REQUIRED | (String) | Randomly generated save token |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/event/io/save_session/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ 1, "Randomly generated save token" ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '[ 1, "Randomly generated save token" ]'
fetch("https://engine.tygron.com/api/event/io/save_session/", options)
