Api event io save project
Revision as of 15:17, 20 November 2026 by Server@tygron.com (talk | contribs)
API Endpoint: api/event/io/save_project/
Description: Save the current state of an EDITOR Session as the current version of the running Project, updating its initial state for future Sessions.
0 REQUIRED (Integer number) Session ID
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/save_project/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '1'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '1'
fetch("https://engine.tygron.com/api/event/io/save_project/", options)
