Api event share update
API Endpoint: api/event/share/update/
Description: Update Shareable content.
| 0 | REQUIRED | (String) | Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/") | |
| 1 | REQUIRED | (byte or multiple values in array [a, b, c]) | Content Bytes |
| 200 | String (String) |
curl 'https://devshare.tygron.com/api/event/share/update/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ "Path", 1 ]'Curl example multi item POST
curl 'https://devshare.tygron.com/api/event/share/update/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ "Path", [ 1, 2, 3 ] ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
body: '[ "Path", 1 ]'
fetch("https://devshare.tygron.com/api/event/share/update/", options)
