Api event share get viewer input
Revision as of 14:50, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/share/get_viewer_input/ Description: Get viewer content array for given path. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (String) | Path (note: viewers end with a slash e.g. "mydir/viewer/") | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 200 | String[] (Array of viewer input shareables.) |- | 300-600 | Codes Overview |} ===Example POST=== Curl example POST <syntaxhighlight...")
0 REQUIRED (String) Path (note: viewers end with a slash e.g. "mydir/viewer/")
200 String[] (Array of viewer input shareables.)
curl 'https://devshare.tygron.com/api/event/share/get_viewer_input/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '"Path"'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '"Path"'
fetch("https://devshare.tygron.com/api/event/share/get_viewer_input/", options)
