Api event io set project version description
API Endpoint: api/event/io/set_project_version_description/
Description: Set the description of a specified version of a Project.
| 0 | REQUIRED | (Integer number) | Session ID | |
| 1 | REQUIRED | (Integer number) | Version of the Project | |
| 2 | REQUIRED | (String) | New version description |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/event/io/set_project_version_description/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ 1, 1, "New version description" ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
body: '[ 1, 1, "New version description" ]'
fetch("https://engine.tygron.com/api/event/io/set_project_version_description/", options)
