Api event io kill
Revision as of 14:48, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/io/kill/ Description: Kill without saving a running Session. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (Integer number) | Session ID | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 200 | Boolean (Content was updated) |- | 300-600 | Codes Overview |} ===Example POST=== Curl example POST <syntaxhighlight lang="text" copy>curl 'https://engine.tygron.com/api/event/io/ki...")
0 REQUIRED (Integer number) Session ID
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/kill/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '1'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '1'
fetch("https://engine.tygron.com/api/event/io/kill/", options)
