Api event io join
API Endpoint: api/event/io/join/
Description: Join a currently running Session
| 0 | REQUIRED | (Integer number) | Session ID | |
| 1 | REQUIRED | (Enumeration) | Application type | EDITOR, LAUNCHER, PARTICIPANT, SERVER, SHARE or TOOLS |
| 2 | OPTIONAL | (String) | Your computer name, for easy identification (optional) | |
| 3 | OPTIONAL | (String) | Your client token, for rejoining (optional) |
| 200 | JoinReply (JoinReply) |
curl 'https://engine.tygron.com/api/event/io/join/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ 1, "LAUNCHER" ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
body: '[ 1, "LAUNCHER" ]'
fetch("https://engine.tygron.com/api/event/io/join/", options)
