Api event io get continuable sessions
API Endpoint: api/event/io/get_continuable_sessions/
Description: Get all Sessions that you can continue, given your token pairs.
| 0 | REQUIRED | (TokenPair or multiple values in array [a, b, c]) | TokenPair array |
| 200 | SessionInfo[] (SessionInfo array) |
curl 'https://engine.tygron.com/api/event/io/get_continuable_sessions/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '
"apiToken" : null,
"clientToken" : null
'Curl example multi item POST
"apiToken" : null,
"apiToken" : null,
"apiToken" : null,
'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
body: '{ "apiToken" : null, "clientToken" : null}'
fetch("https://engine.tygron.com/api/event/io/get_continuable_sessions/", options)
