Api event io close
Revision as of 14:39, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/io/close/ Description: Disconnect the Application from a running Session, optionally closing it if this was the last connected application. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (Integer number) | Session ID | |- | 1 | REQUIRED | (String) | Client Session token | |- | 2 | REQUIRED | (true, false) | Keep Session running, even if this was the last client | true or false |} ===Respon...")
0 REQUIRED (Integer number) Session ID
1 REQUIRED (String) Client Session token
2 REQUIRED (true, false) Keep Session running, even if this was the last client true or false
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/close/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ 1, "Client Session token", true ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '[ 1, "Client Session token", true ]'
fetch("https://engine.tygron.com/api/event/io/close/", options)
