Api event io add project version
Revision as of 14:39, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/io/add_project_version/ Description: Create a new version for this Project. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (Integer number) | Session ID | |- | 1 | REQUIRED | (String) | Version Name | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 204 | No Content |- | 300-600 | Codes Overview |} ===Example POST=== Curl example POST <syntaxhighlight lang="text" copy>curl 'ht...")
0 REQUIRED (Integer number) Session ID
1 REQUIRED (String) Version Name
204 No Content
curl 'https://engine.tygron.com/api/event/io/add_project_version/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ 1, "Version Name" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '[ 1, "Version Name" ]'
fetch("https://engine.tygron.com/api/event/io/add_project_version/", options)
