How to add or remove a Scenario
Revision as of 10:00, 18 November 2026 by Server@tygron.com (talk | contribs)
Editor → Multi Scenario (Ribbon tab) → Scenario (Ribbon bar)
Adding a Scenario
Add a scenario via the ribbon drop-down menu or the Add button at the bottom of the left panel.
How to add scenario to a project:
  1. Select Multi Scenario → Scenarios
  2. Select Add new Scenario from the drop-down menu
  3. Or select Add on the bottom of the left panel.
Removing a Scenario from a project
How to remove scenario in a project:
  2. Select the scenario to be removed on the left panel
  3. Select Remove on the bottom of the left panel
