How to draw selections for buildings
Revision as of 09:52, 18 November 2026 by Server@tygron.com (talk | contribs)
How to Change buildings:
  1. Select Buildings from Current Situation
  2. Search in the list or the 3D Visualization for the building to be changed.
  3. Select the name or building.
  4. In the right detail panel, click the "Draw" button to select the building in the 3D Visualization.
Click the 'Draw Area' button at the bottom of the panel to draw the building in the 3D Visualization. A new panel - the Brush Panel - becomes available under the editor main view port:
Left-click and drag in the 3D Visualization's main view to draw the building's ground plan. Colors indicate if the area is available for the selected building. Choose a selection type, such as rectangles for buildings or lines for roads. Click 'Apply Selection' to confirm the building. 'Clear Selection' removes the selection from the 3D Visualization. Use the 'Remove' operator to delete existing buildings from the project; the building slot remains as an empty entry.
