Excel Panel
Revision as of 15:32, 12 November 2026 by Frank@tygron.nl (talk | contribs)
Calculation Model
The text content of an Excel Panel is calculated using an Excel Spreadsheet. The Excel spreadsheet general contains:
  • Select (TQL) queries to read data from the Project Session.
  • Formula's performed on the data
  • Update (TQL) and excel panel specific names to write data to the Project Session;
The TQL Queries are specified in an Excel using Naming cells.
Specific names for writing data:
  • EXPLANATION: written to the text property of a panel; Rendered as HTML, seen in a viewers Text Panel and obtained using the Web panel endpoint.
Web interface
Main article: Web interface
The Web interface can be enriched by adding a Panel to it with HTML, CSS and/or javaScript code. The content of the Panel is directly injected into the Web interface.
Example
As an example, in the case of a dynamic traffic model, information can be retrieved first (using SELECT-queries), after which these data are processed according the following specifications in the Excel file. The end product may be the calculated traffic intensities at various locations in the project map. Using UPDATE-queries, these results can subsequently adjust the visibility of the Excel panel's Popup. Stakeholders will not notice anything of the underlying calculation model, except for its results (e.g., changing traffic intensities).
