Api session event editor weather set trigger sec
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorweather/set_trigger_sec/
Description: Set the Trigger Time for the specified Weather's visualization
0 REQUIRED (WEATHER Integer ID) Weather
1 REQUIRED (Floating point number) Auto-Trigger time in seconds
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorweather/set_trigger_sec/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 47 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorweather/set_trigger_sec/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 93 ]'
JavaScript example POST
 body: '[ 1, 47 ]'
fetch("https://engine.tygron.com/api/session/event/editorweather/set_trigger_sec/", options)
