Api session event editor setting set tql token
API Endpoint: api/session/event/editorsetting/set_tql_token/
Description: Set if TQL Queries are allowed access the API token
| 0 | REQUIRED | (true, false) | True for allow, false to disable TQL API tokens | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_tql_token/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'JavaScript example POST
body: 'true'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_tql_token/", options)
