Api session event editor setting set import crs
API Endpoint: api/session/event/editorsetting/set_import_crs/
Description: Set the Default Import CRS, used in the Geo Import Wizard
| 0 | REQUIRED | (String) | EPSG CRS Code |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_import_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"EPSG CRS Code"'JavaScript example POST
body: '"EPSG CRS Code"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_import_crs/", options)
