Api session event editor panel set visible
API Endpoint: api/session/event/editorpanel/set_visible/
Description: Set whether a Panel is visible in the 3D Visualization
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | REQUIRED | (true, false) | Visible | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_visible/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'JavaScript example POST
body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_visible/", options)
