Api session event editor panel set url
API Endpoint: api/session/event/editorpanel/set_url/
Description: Set the URL of a Web Panel
| 0 | REQUIRED | (PANEL Integer ID) | Web Panel | |
| 1 | REQUIRED | (String) | URL |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "URL" ]'JavaScript example POST
body: '[ 1, "URL" ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_url/", options)
