Api session event editor panel set size
API Endpoint: api/session/event/editorpanel/set_size/
Description: Set the interface size of a Panel
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | REQUIRED | (Floating point number) | Width | |
| 2 | REQUIRED | (Floating point number) | Height |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 85, 77 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 13, 0 ]'JavaScript example POST
body: '[ 1, 85, 77 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_size/", options)
