Api session event editor overlay set show system visualization
API Endpoint: api/session/event/editoroverlay/set_show_system_visualization/
Description: Set whether a Water Overlay visualizes the graph of systems which dictates its calculation. Pipes, center Points of Areas, etc
| 0 | REQUIRED | (OVERLAY Integer ID) | Water Overlay | |
| 1 | REQUIRED | (Enumeration) | Water System | AREAS or OBJECTS |
| 2 | REQUIRED | (true, false) | Visualized | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_show_system_visualization/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "OBJECTS", true ]'JavaScript example POST
body: '[ 1, "OBJECTS", true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_show_system_visualization/", options)
