Api session event editor indicator set parent
Revision as of 14:51, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorindicator/set_parent/
Description: Set a parent Indicator for a specified Indicator, making it a subselectable Indicator. An Indicator that already has a parent cannot be assigned as a parent to another Indicator
0 REQUIRED (INDICATOR Integer ID) Indicator
1 REQUIRED (Integer number) Parent Indicator ID (use -1 if no parent exists)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorindicator/set_parent/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorindicator/set_parent/", options)
