Api session event editor geotiff add url
API Endpoint: api/session/event/editorgeotiff/add_url/
Description: Add a new GeoTIFF from a Web URL
| 0 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | GeoTIFF Names | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Web URLs | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Uploaders | |
| 3 | OPTIONAL | (String or multiple values in array ["a", "b", "c"]) | Override CRSs |
| 200 | Integer[] (GeoTIFF IDs) |
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name 1", "Web URL 1", "Uploader 1" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "GeoTIFF Name 1", "GeoTIFF Name 2", "GeoTIFF Name 3" ], [ "Web URL 1", "Web URL 2", "Web URL 3" ], [ "Uploader 1", "Uploader 2", "Uploader 3" ] ]'JavaScript example POST
body: '[ "GeoTIFF Name 1", "Web URL 1", "Uploader 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/add_url/", options)
