Api session event editor panel set template relation
API Endpoint: api/session/event/editorpanel/set_template_relation/
Description: Set which Relation is used by a Template Panel to create Panel instances
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | OPTIONAL | (Enumeration) | Maplink |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_template_relation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_template_relation/", options)
