Api session event editor panel export excel call tree
Revision as of 09:01, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorpanel/export_excel_call_tree/
Description: Export a performance report of an Excel Sheet, populated with data related to the Excel Panel, to text as Byte array content
0 REQUIRED (PANEL Integer ID) Excel Panel
200 byte[] (Byte array content)
curl 'https://engine.tygron.com/api/session/event/editorpanel/export_excel_call_tree/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorpanel/export_excel_call_tree/", options)
