Api session event editor panel edit answer event
API Endpoint: api/session/event/editorpanel/edit_answer_event/
Description: Replace the Coded Event of a Server or Clientside Event of an Answer of a Panel, using the Coded Event ID
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | REQUIRED | (Integer number) | Answer ID | |
| 2 | REQUIRED | (true, false) | Server side | true or false |
| 3 | REQUIRED | (CodedEvent) | Coded Event |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/edit_answer_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, true, {
"id" : -1,
"parameters" : [ ]
'JavaScript example POST
body: '[ 1, 1, true, { "id" : -1, "parameters" : [ ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/edit_answer_event/", options)
