Api session items netloads
Revision as of 16:06, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/netloads/
Edit items with events described at Api session event editor netload.
Default Query:
https://engine.tygron.com/api/session/items/netloads/?token=API_TOKEN
Example Response:
  "addressIDs" : [ ],
  "attributes" : {
    "ROOT_LOAD" : [ 1.0 ]
  "buildingID" : -1,
  "clusterID" : -1,
  "connectionState" : "NOTHING",
  "id" : 0,
  "maquetteOverride" : null,
  "name" : "NetLoad 0",
  "netType" : "ELECTRICITY",
  "nodeID" : 0,
  "point" : null,
  "sourceIDs" : [ ],
  "version" : 21
  "addressIDs" : [ 90 ],
  "attributes" : {
    "TYPE" : [ 5.0 ]
  "buildingID" : 444,
  "clusterID" : 0,
  "id" : 1,
  "name" : "NetLoad 1",
  "nodeID" : 2,
  "point" : null,
  "sourceIDs" : [ 12 ],
  "version" : 22
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/netloads/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/netloads/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/netloads/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/netloads/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/netloads/?crs=LOCAL&token=API_TOKEN
Bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/netloads/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/net_loads-foo/?crs=3857&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/netloads/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/netloads/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/netloads/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/netloads/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/netloads/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/netloads/?f=JSON&token=API_TOKEN
GEOJSON:
https://engine.tygron.com/api/session/items/netloads/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/netloads/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/netloads/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/netloads/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/netloads/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/netloads/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/netloads/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/netloads/?f=ZIPSMILE&token=API_TOKEN
Api Model NetLoad
API Model description of NetLoad
Name Type Description
addressIDs int[] Addresses ID
attributes Map<String,double[]>
buildingID int Building ID
clusterID int Net Cluster ID
connectionState TimeState Timestate
id int
maquetteOverride Map<String,double[]>
name String
netType NetType Net Type
nodeID int Net Node ID
point Point Point
sourceIDs int[] Sources ID
version int
Api Model NetType
API Enumeration description of NetType
Name Description
ELECTRICITY
GAS
HEAT
INTERNET
SEWER
Api Model Point
API Model description of Point
type String Point
coordinates double[] x, y, (optional) z
Api Model TimeState
API Enumeration description of TimeState
Name Description
NOTHING
WAITING_FOR_DATE
REQUEST_PLOT_OWNER_APPROVAL
REQUEST_ZONING_APPROVAL
REQUEST_CONSTRUCTION_APPROVAL
CONSTRUCTION_APPROVED
CONSTRUCTION_DENIED
PENDING_CONSTRUCTION
CONSTRUCTING
READY
PENDING_UPGRADE
WAITING_FOR_DEMOLISH_DATE
REQUEST_DEMOLISH_ZONING_APPROVAL
REQUEST_DEMOLISH_APPROVAL
DEMOLISH_APPROVED
DEMOLISH_DENIED
PENDING_DEMOLISHING
DEMOLISHING
DEMOLISH_FINISHED
