Api session event logic stakeholder release
API Endpoint: api/session/event/logic/stakeholder_release/
Description: Release a Stakeholder from a Session.
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/stakeholder_release/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/logic/stakeholder_release/", options)
