Api session event logic measurement line add
API Endpoint: api/session/event/logic/measurement_line_add/
Description: Add a Line Measurement for an Overlay for a specific Timeframe.
| 0 | REQUIRED | (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) | Overlays | |
| 1 | REQUIRED | (Point with crs: EPSG:3857) | Point start | |
| 2 | REQUIRED | (Point with crs: EPSG:3857) | Point end | |
| 3 | REQUIRED | (String) | Name | |
| 4 | REQUIRED | (Integer number) | Timeframe (-1 for automatic last) | |
| 5 | REQUIRED | (true, false) | Save Measurement | true or false |
| 6 | REQUIRED | (true, false) | Sum | true or false |
| 200 | Integer (Measurement) |
curl 'https://engine.tygron.com/api/session/event/logic/measurement_line_add/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658797.1534114793, 6799449.129132586 ]
"type" : "Point",
"coordinates" : [ 658675.1353150207, 6799350.229749473 ]
}, "Name", -1, true, true ]
'Curl example multi item POST
[ [ 1, 2, 3 ], {
"type" : "Point",
"coordinates" : [ 658754.4158943058, 6799386.108124475 ]
"type" : "Point",
"coordinates" : [ 658696.6616148085, 6799360.52501269 ]
'JavaScript example POST
body: '[ 1, { "type" : "Point", "coordinates" : [ 658797.1534114793, 6799449.129132586 ]}, { "type" : "Point", "coordinates" : [ 658675.1353150207, 6799350.229749473 ]}, "Name", -1, true, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_line_add/?crs=3857", options)
