Api session event editor parametric add plot
Revision as of 15:31, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorparametric/add_plot/
Description: Add a Plot Design of a particular Function to a Parametric Design
0 REQUIRED (PARAMETRIC_DESIGN Integer ID or multiple integer values in array [1, 2, 3]) Parametric Designs
1 REQUIRED (FUNCTION Integer ID or multiple integer values in array [1, 2, 3]) Functions
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorparametric/add_plot/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorparametric/add_plot/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorparametric/add_plot/", options)
