Api session event editor netload import
API Endpoint: api/session/event/editornetload/import/
Description: Import a Collection of Net Load geometries, names, Net Types, Net state, to an existing Net by adding Net Lines with the provided Net Function. A Building is assigned to a Net Load when within Building range. A Net Load is assigned to a Net Node when within Net Node range.
| 0 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | Net Load Geometries | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Names | |
| 2 | REQUIRED | (NetType or multiple values in array [a, b, c]) | Net Types | |
| 3 | REQUIRED | (TimeState or multiple values in array [a, b, c]) | Net state | |
| 4 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Concateneted Addresses | |
| 5 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attributes | |
| 6 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | Attribute Values array | |
| 7 | REQUIRED | (Integer number) | Index of Root Load Geometry | |
| 8 | REQUIRED | (Floating point number) | Building Range | |
| 9 | REQUIRED | (Floating point number) | Net Node Range | |
| 10 | REQUIRED | (SOURCE Integer ID) | Source |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/import/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
"type" : "GeometryCollection",
"geometries" : [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "Name 1", "ELECTRICITY", "NOTHING", "Concateneted Addresse 1", "Attribute 1", [ 1.0, 2.0 ], 1, 52, 30, 1 ]
'Curl example multi item POST
"geometries" : [ {
"coordinates" : [ [ [ [ 658646.762, 6799451.896 ], [ 658646.762, 6799461.896 ], [ 658656.762, 6799461.896 ], [ 658656.762, 6799451.896 ], [ 658646.762, 6799451.896 ] ] ] ]
"coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
}, [ "Name 1", "Name 2", "Name 3" ], [ "ELECTRICITY", "GAS", "HEAT" ], [ "NOTHING", "WAITING_FOR_DATE", "REQUEST_PLOT_OWNER_APPROVAL" ], [ "Concateneted Addresse 1", "Concateneted Addresse 2", "Concateneted Addresse 3" ], [ "Attribute 1", "Attribute 2", "Attribute 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], 1, 72, 53, 1 ]
'JavaScript example POST
body: '[ { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, "Name 1", "ELECTRICITY", "NOTHING", "Concateneted Addresse 1", "Attribute 1", [ 1.0, 2.0 ], 1, 52, 30, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/import/?crs=3857", options)
