Api session event editor netline insert point
API Endpoint: api/session/event/editornetline/insert_point/
Description: Insert a new Node in an existing Net Line, potentially splitting the Net Line into two parts. Also specify at what distance the new Nodes are merged with existing Nodes.
| 0 | REQUIRED | (NET_LINE Integer ID) | Net Line | |
| 1 | REQUIRED | (Point 3D with crs: EPSG:3857) | Inserted Node Point | |
| 2 | OPTIONAL | (Floating point number) | Node merge distance (optional, default: 1.0m) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetline/insert_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658794.9315933029, 6799459.1695323065, -0.87 ]
'Curl example multi item POST
[ 1, {
"type" : "Point",
"coordinates" : [ 658675.7443660558, 6799456.993190969, -0.45 ]
'JavaScript example POST
body: '[ 1, { "type" : "Point", "coordinates" : [ 658794.9315933029, 6799459.1695323065, -0.87 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetline/insert_point/?crs=3857", options)
