Api session event editor indicator export excel call tree
API Endpoint: api/session/event/editorindicator/export_excel_call_tree/
Description: Export a performance report of an Excel Sheet, populated with data related to the Indicator, to text as Byte array content
| 0 | REQUIRED | (INDICATOR Integer ID) | Indicator |
| 200 | byte[] (Byte array content) |
curl 'https://engine.tygron.com/api/session/event/editorindicator/export_excel_call_tree/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorindicator/export_excel_call_tree/", options)
