Api session event editor indicator export debug excel
Revision as of 15:30, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorindicator/export_debug_excel/
Description: Export an Excel Sheet, populated with data related to the Indicator, to Byte array content
0 REQUIRED (INDICATOR Integer ID) Indicator
200 byte[] (Byte array content)
curl 'https://engine.tygron.com/api/session/event/editorindicator/export_debug_excel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorindicator/export_debug_excel/", options)
