Api session event editor indicator add
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorindicator/add/
Description: Add a new Indicator with a default Excel Sheet
200 Integer (Indicator ID)
curl 'https://engine.tygron.com/api/session/event/editorindicator/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST
 body: ''
fetch("https://engine.tygron.com/api/session/event/editorindicator/add/", options)
