Api session event editor geoplugin set layer name
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorgeoplugin/set_layer_name/
Description: Set the Layer used by a Geo Plugin to obtain data from its Source
0 REQUIRED (GEO_PLUGIN Integer ID or multiple integer values in array [1, 2, 3]) Geo Plugins
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Layer Names
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_layer_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Layer Name 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_layer_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Layer Name 1", "Layer Name 2", "Layer Name 3" ] ]'
JavaScript example POST
 body: '[ 1, "Layer Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeoplugin/set_layer_name/", options)
