Api session event editor geoplugin set force xy
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorgeoplugin/set_force_xy/
Description: Override the CRS's Force XY parameter, used by a Geo Plugin to transform data from its Source
0 REQUIRED (GEO_PLUGIN Integer ID or multiple integer values in array [1, 2, 3]) Geo Plugins
1 REQUIRED (Boolean or multiple boolean values in array [true, false, true]) Booleans
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_force_xy/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_force_xy/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorgeoplugin/set_force_xy/", options)
