Api session event editor functionoverride
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorfunctionoverride/
API Endpoints for Function Override editing.
Name Description
add Add a Function Override for the provided Function
duplicate Duplicate a Function
remove_attribute Remove an Attribute from a Function
set_attribute Set Function Override numeric Attribute value
set_attributes Set multiple Function Override numeric Attribute values
set_name Set the name of a Function
Additional API Endpoints:
Name Description
add_category Add a Category to a Function, if allowed by the Function's main Category
remove_category Remove a Category from a Function, if it has more than one
reset Reset a Function
reset_assets Reset the asset properties of a Function
reset_values Reset Values
set_category_value Set the Category Value of a Function
set_description Set the description of a Function
set_function_value Set the Function Value of a Function
set_image Set the image of a Function
